Yes, I'm using the new "Extensions Top" config files.
I'm working with medm3_1_2_1. Please understand that this is part of
my project to port Epics to NetBSD, so I'm sure it's just something that
is not being picked up by someone.
I'll capture a logfile of the compile, next time I compile the package,
but the command I use is simply to move to the extensions directory, and
type 'gmake' (NetBSD uses normal BSD 'make' as it's default make
program).
David
>>> "J. Lewis Muir" <[email protected]> 3/11/2008 9:17 AM >>>
On 3/11/08 9:35 AM, David Dudley wrote:
> Oh, so it's that file. I was looking for something in base. I have
> that file, and I have the settings set correctly in it. However,
when I
> get over to the build for MEDM, the variables appear to be blank.
This
> is only happening on MEDM, not on any of the other extensions.
> David
Hi, David.
What version of EPICS base are you using?
Are you using the new "Extensions Top" config files from
http://www.aps.anl.gov/epics/extensions/configure/index.php
What version of MEDM are you trying to compile?
Could you send the commands you're using to compile MEDM and their
output?
Lewis
J. Lewis Muir
Software Engineer
CARS/IMCA-CAT
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
- Re: Building MEDM David Dudley
- Building MEDM David Dudley
- RE: Building MEDM Hammonds, John P.
- RE: Building MEDM David Dudley
- Re: Building MEDM J. Lewis Muir
<2008>
<2008>
