1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM fundamentals ....
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Mon, 17 Mar 2008 12:03:01 -0400
Emmanuel Mayssat wrote:
Hello,
I have been using medm for a long time.
I just moved to edm.
I use the adl2edl script for migration.
I need clarifications on the following undocumented features.
1/ what is an action file?
See user's manual available at http://ics-web4.sns.ornl.gov/edm/, chapter 14
2/ I found colors.list and fonts.list in the edm installation. How can I
create or modify them?
user's manual chap 3
3/ I am now using edm files from an outside source. My color scheme
doesn't work at all with those displays. Is there a reason for that?
edm implements functional colors; functions don't change (or so they say)
but the corresponding color may. So its easy to change the color later on.
An undesirable side effect (as you note) is that you can't use external files
that use a different color/function mapping. You may import them into your
environment as follows:
  - run edm -color rgb (using external colors.list file) and save the file
  - run edm (using your colors.list file) and save the file
4/ What are calc.list and how can I use them? Does that mean that fancy
calculation can be done at the GUI level? Do you recommend those?
user's manual, chap 6
5/ What is an edm server? I assume my localhost should be an edm server
for all of my local edm displays? If so, how can I configure it that
way? EDMSERVERS, etc.
6/ The edm environment (as read through the edm gui) includes a lot of environment variables. For example EDMXSYNC, EDMSUPERVISOR, etc. Where can I find a detailed description of those variables?
user's manual, chap 4
however, not all are described; some are similar to k3b's "use-the-force-luke" option.
7/ While we are at it. I have difficulties understanding all of the
options to edm. Are they better documented somewhere else than in edm
-h?
probably not
8/ adl2edl converts my adl files by using the hevetica fonts, which is
too small. Is there a way to select fonts, etc. for the adl2edl
conversion?
i've no clue about this one
Emmanuel Mayssat
EDM fundamentals .... Emmanuel Mayssat
Prev: EDM fundamentals .... Emmanuel Mayssat
Next: RE: Problem with soft motor record Rarback, Harvey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Listen to multiple events Dehong Zhang
