Subject: Re: EPICS: Selecting a Text Error Message
To: [email protected]
Date: Fri, 21 Mar 2008 19:58:21 +0100
On Donnerstag, 20. März 2008, Schoeneburg, Bernd wrote:
> I have created a "strtabRecord" (string Table Record) for exactly this
> problem. It uses an externally loaded string library. The library
> contains the string tables. Each entry consists of the integer number, a
> string and an alarm severirty. If the input number is not defined in the
> table, the record will display the number instead and the alarm severity
> will be set to the predefined (UNSV). You can select a different table
> during runtime. Connecting the library works similar to the subroutine
> record. If you are interested I can send you the sources.
This sound pretty cool. Would it be possible for you to set up a web page
where people can download this (and also add an entry to the EPICS modules
directory)?
Cheers
Ben
EPICS: Selecting a Text Error Message David Dudley
Re: EPICS: Selecting a Text Error Message Schoeneburg, Bernd
Prev: Re: EPICS: Selecting a Text Error Message David Dudley
Next: VME module identification tagging and storage Harms, Michael JJ
Next: CALC expression feature request Benjamin Franksen
