You may want to look at the -noMsg option of medm.
Are you sure the problem you are having is related to the version OS?
I have several problems with medm (and edm BTW), but in my case it seems
to be related to the version of the epics base I am building against.
My medm (3.1.1+) works when build on epics base 3.4.6 and but not with
3.4.9 ( compile, execute, but never connect to IOC)
Conversely, my edm (1_10_1d+) works when compiled against 3.4.9 but not
with 3.4.6 (doesn't compile easily)
Good luck,
E
On Wed, 2008-03-26 at 17:32 -0500, Rodney R. Porter wrote:
> I get the following error from MEDM on Fedora Core 4, with similar
> unexplained MEDM communication hangs on Fedora Core 6:
> medmCAExceptionHandlerCb: Channel Access Exception:
> Too many exceptions [25]
> No more will be handled
> Please fix the problem and restart MEDM
> As far as I have been able to tell, the exceptions are generated when an ioc
> is restarted. Does anyone have any other experience with this error?
> Rodney Porter
> Nanoprobe Beamline
- Re: MEDM CA Exception Limit Emmanuel Mayssat
- MEDM CA Exception Limit Rodney R. Porter
Install StripTool 米清茹
<2008>
2025
<2008>
2025
