Yes, the 129.57.239.255 is the broad address for the 236 subnet. I have
tried using the actual address (129.57.236.20) also but neither seems
to open the flood gates of communication.
Any other thoughts?
Thanks in advance,
Sue
Andrew Johnson wrote:
Hi Sue,
Sue Witherspoon wrote:
I have a curious problem concerning multi-subnet connectivity when
converting from Epics 3.13.2 to Epics 3.14.8.2. Using the same
network setup and database the 3.13 db can communicate across subnets
while the 3.14 db gets a link error.
I'm having difficulty understanding your subnet architecture; the IP
addresses you're using don't seem to match up — I think you just have
a typo in your EPICS_CA_ADDR_LIST setting.
From your description you have a heartbeat calc record on iocmc1
(129.57.236.20) which you would like to monitor from an ai record on
iocfb1 (129.57.230.101). In order for that link to work, the
EPICS_CA_ADDR_LIST on iocfb1 must include the 129.57.236.xxx subnet,
but you're pointing it to the 129.57.239.xxx subnet instead:
resource.def file for iocfb1
putenv ("EPICS_CA_AUTO_ADDR_LIST = YES")
putenv ("EPICS_CA_ADDR_LIST = 129.57.239.255")
HTH,
- Andrew
- Re: cross subnet CA communication Sue Witherspoon
- cross subnet CA communication Sue Witherspoon
- Re: cross subnet CA communication Andrew Johnson
<2008>
2025
<2008>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
