1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: multiple levels of substitution in msi
To: "Allison, Stephanie" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 15 Apr 2008 16:38:07 -0400
Stephanie,
I haven't changed any build RULES. I looked at several working IOCs that use substitution and they never seem to call MSI with the /db directories from device support, so I definitely do not get the DBFLAGS you describe.
e.g.
make[3]: Entering directory `/a/erp101/nfs/erl/erp/epics/R3.14.9/ioc/l0_phase1a/l0_phase1aApp/Db/O.linux-x86'
Inflating database from ../eos900.substitutions ../eos900.template
msi -I. -I.. -I../O.Common -S../eos900.substitutions ../eos900.template > msi.tmp
mv msi.tmp ../O.Common/eos900.db
Inflating database from ../MAGNET.substitutions ../MAGNET.template
msi -I. -I.. -I../O.Common -S../MAGNET.substitutions ../MAGNET.template > msi.tmp
mv msi.tmp ../O.Common/MAGNET.db
Inflating database from ../MAGPOL.substitutions ../MAGPOL.template
msi -I. -I.. -I../O.Common -S../MAGPOL.substitutions ../MAGPOL.template > msi.tmp
mv msi.tmp ../O.Common/MAGPOL.db
Inflating database from ../MAGPS.substitutions ../MAGPS.template
msi -I. -I.. -I../O.Common -S../MAGPS.substitutions ../MAGPS.template > msi.tmp
There aren't any templates in these device support /db directories so it has never been as issue.
Any ideas how could my build rules could get broken?
John
Allison, Stephanie wrote:
Hi John,
Your rule for inflating the database isn't properly using DBFLAGS so it doesn't have the directories with "db" in the include list. Is it possible you are using a rule that is different from the one in base/configure/RULES.Db?
Here is an example from my build (I have several modules included in my RELEASE which is why the long list of potential areas to find database files):
Inflating database from ../evrEventAll.substitutions /nfs/slac/g/lcls/build/epics/extensions/extensions-R3-14-8-2/bin/linux-x86/msi -I. -I.. -I ../../../../db -I /nfs/slac/g/lcls/build/epics/modules/generalTime/generalTime-R1-2-1/db -I /nfs/slac/g/lcls/build/epics/modules/sSubRecord/sSubRecord-R1-0-1/db -I /nfs/slac/g/lcls/build/epics/modules/miscUtils/miscUtils-R1-0-1/db -I /nfs/slac/g/lcls/build/epics/base/base-R3-14-8-2-lcls2/db -I../O.Common -S../evrEventAll.substitutions > msi.tmp
mv msi.tmp ../O.Common/evrEventAll.db
If you are using your own rule, you may need to add the "db" in front of the file name. For example:
file db/firstAll.db {
pattern { DEVICE }
{ device1 }
{ device2 }
{device30}
Stephanie
-----Original Message-----
From: John Dobbins [mailto:[email protected]] Sent: Tuesday, April 15, 2008 12:21 PM
To: Allison, Stephanie
Cc: EPICS Tech-Talk
Stephanie,
Using your suggestion (from January) I tried unsuccessfully to get MSI to do multiple levels of substitution. I am using 3.14.9 but I assume that is not the issue.
Setup:
#1  xxx
#2     Makefile
#3     configure/
#4     iocBoot/
#5     xxxApp/
#6        Makefile
#7        Db/
#8           first/
#9              Makefile
#10             firstAll.substitutions
#11             firstAll.template
#12          second/
#13             Makefile
#14             second.substitutions
#15       src/
Fails with:
    Inflating database from ../second.substitutions
    msi   -I. -I.. -I../O.Common -S../second.substitutions  > msi.tmp
    Could not open firstAll.db
firstAll.db exists but not in any of the places MSI is looking. How do I get MSI to find it?
Details:
#6 Makefile is:
    TOP=../..
    include $(TOP)/configure/CONFIG
    DIRS += first
    DIRS += second
include $(TOP)/configure/RULES_DIRS
#9 Makefile is:
    TOP=../../..
DB = firstAll.db
#13 Makefile is:
    TOP=../../..
DB = second.db
John Dobbins
Cornell University
Lab for Elementary Particle Physics
Hi John,
Is there a way to get MSI to deal with multiple levels of substitution?
I divide my Db directory into sub-directories and build
them in the proper order. For example:
xxxApp/Db/first contains Makefile, first.db, and
firstAll.substitions:
Makefile has:
DB += firstAll.db
firstAll.substitutions which looks something like this:
file first.db {
pattern { DEV , CARD , NAME , ID
,P0,P1,P2,P3,P4,P5,P6,P7,P8,P9,P10,P11,P12,P13,VME}
{ $(DEVICE) , 0 , NAME1 , 1 , 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0 , 0 , 0 , 0 , 1 }
{ $(DEVICE) , 0 , NAME2 , 2 , 1, 0, 0,
{ $(DEVICE) , 0 , NAME15 , 12 , 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0 , 0 , 0 , 1 , 1 }
xxxApp/Db/second contains Makefile, second.substitutions:
Makefile has:
DB += second.db
second.substitutions looks something like this:
file firstAll.db {
pattern { DEVICE }
{ device1 }
{ device2 }
{device30}
and xxxApp/Db/Makefile looks like:
TOP = ../..
# first must be first since second will need for the
.db file created by first
DIRS += first DIRS += second
The RULES.Db files that come with epics 3.14.8.2 will do
the MSI properly - I don't think we had to change RULES.Db for this.
If you don't like sub-directories, just create more *Db
directories under xxxApp:
xxxApp/CommonDb1
xxxApp/CommonDb2
xxxApp/Db (which depends on CommonDb1 and CommonDb2
being built first)
xxxApp/Makefile must enforce proper build order
Note there is a bug in the RULES somewhere that requires
the "{" that comes after the "file xxxx.db" to be on the next line if xxxx.db comes from another module listed in your RELEASE file.
Doesn't work:
file xxxx.db {
Works: file xxxx.db
Hope this helps more than confuses...
Stephanie Allison
RE: multiple levels of substitution in msi Allison, Stephanie
multiple levels of substitution in msi John Dobbins
Re: multiple levels of substitution in msi John Dobbins
Prev: RE: multiple levels of substitution in msi Allison, Stephanie
Next: Re: multiple levels of substitution in msi John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: multiple levels of substitution in msi Allison, Stephanie
