Subject: RE: autosave issues
Cc: epics <[email protected]>
Date: Wed, 16 Apr 2008 17:11:10 -0700
Mark,
I implemented autosave relatively easily thanks to the documentation.
For the set_passX_restoreFile functions, it says that only 8 files can
be restored at each pass.
This is rather an important limitation if I have a restore file per
device (and not 1 per ioc). Is this limitation still applicable?
Is doing a restore at pass0 equivalent to setting the VAL fields in the
db file? For pass1, is it equivalent to having several caputs on a
running ioc?
Why do they recommend saving vxWorks station over NFS? I assume it is
only because of a storage space limitation. If that is the case, then it
is not applicable for computer-based IOC. Isn't it?
E
On Tue, 2008-04-15 at 21:22 -0500, Mark Rivers wrote:
> The problems are probably less frequent than that.  And a beamline might be 4 IOCs.
> The issues tend to arise during power or network failures when the vxWorks VME IOC is in the middle of saving the file via NFS.
> There are safeguards now in place that make this much less likely.  And there are backup files created by the autosave system that can be recovered from.
> Mark
> ________________________________
> From: [email protected] on behalf of Emmanuel Mayssat
> Sent: Tue 4/15/2008 8:35 PM
> To: epics
> Subject: autosave issues
> Hello again,
> I was looking at autosave record/functions.
> I read that APS is experiencing at least 1 autosave issue per beamline,
> per year. Can anyone expend on that?
> I assume that files are being corrupted or such...
> How could that happen?
> Emmanuel
RE: autosave issues Mark Rivers
autosave issues Emmanuel Mayssat
Prev: Re: edm font init failed solution Matthieu Bec
Next: RE: autosave issues Mark Rivers
Prev: RE: autosave issues Mark Rivers
