Wow!
Hello all,
procServ is an application originally written by
Dave Thompson at SNS that creates an environment for running processes (such as
soft IOCs) in the background while providing access to the console through a
telnet port.
I recently added some options and fixed a few things -
here's what it does now:
- Can be used either standalone (it creates log files if told so), or under
a central console access layer like conserver.
- The auto-restart mode (can be toggled and configured) immediately restarts
a soft IOC on exit or crash.
- Has commands to manually shutdown and restart the soft IOC without losing
the telnet connection.
- Can be configured to write a daemon PID file to be used in standard system
service scripts.
- Console access is restricted to connections from localhost for security
reasons, while you can configure a second, public, read-only port to allow
other logging facilities to connect without going through an account.
For a more detailed description, see the documentation. Download
the application here.
Enjoy!
Cheers, Ralph
- procServ V2.1.0 soft IOC server released Ralph Lange
RE: Multiple IOCs on the same Host - question on dynamically allocatedTCP Ports Thompson, David H.
Re: asyn/stream reconnect problems Allison, Stephanie
<2008>
Multiple IOCs on the same Host - question on dynamically allocated TCP Ports Allison, Stephanie
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
