Subject: Re: Listing channels
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Wed, 07 May 2008 09:20:27 -0500
David Dudley wrote:
Got 3 little questions:
1. Is there a method or application anywhere that can generate a list of
the channels on a remote IOC? I mean, a program I can point at the
IOC's address and have it generate a list of all the channels on that
unit?
2. Does SDDS require X in order to compile?  It's a given that SDDSPlot
is probably going to need X, but most of the apps don't have GUI's, so
must X be available in order to compile them?  If not, how do you
generate the non-X programs?
sddsplot, sddscontour and mpl_motif are the only SDDS programs that need X. These are compiled after all the other programs so if you get this far everything else is already compiled.
3. Is there a program that will extract a portion of an SDDS file?  In
order to use SDDS for archiving (which it looks like it might be very
useful for), it's going to have to run forever on the IOC unit.  If I
need to generate a dataset from a SDDS datafile, how do I pull out just
the period (say... everything from yesterday, midnite to midnite) from a
file that has much, much more information in it (days, weeks, or months
...)?  I can come up with stuff to cause it to restart, say once a week,
but how do I pull out a subset of information?
When you log the data using a program like sddslogger it will include a Time column that you can then filter on using sddsprocess with the -filter=column,Time,<minvalue>,<maxvalue> option.
--Bob Soliday
Listing channels David Dudley
Prev: Re: Listing channels Ned Arnold
Next: Re: Listing channels David Dudley
