1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: IP Card Problems on the Acromag Carrier 9670
To: "'Andrew Johnson'" <[email protected]>
Cc: [email protected]
Date: Fri, 9 May 2008 16:20:04 +0100
Hi Andrew,
Indeed it is mainly people who have either converted Andy Foster
original driver to RTEMS and we did the tests with the original as well
under VxWorks.
Glad you fixed it in drvIpac, should have just checked with you first.
Many thanks for confirming the change, so I guess we can say no one
should have any Hytec IP Card / 9670 problems if they use drvIpac 2.9.
Regards
Darrell Nineham
Hytec Electronics Ltd.
Tel: +44 (0) 118 975 7770
Fax: +44 (0) 118 975 7566
Web: www.hytec-electronics.co.uk
Incorporated in England No 1246940
VAT NO GB 285 2479 27
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they are
addressed. If you have received this email in error, please notify the
sender immediately. The views expressed in the message are those of the
individual author and may not necessarily represent the views of Hytec
Electronics Ltd.
-----Original Message-----
Sent: 09 May 2008 15:45
To: Darrell Nineham
Subject: Re: IP Card Problems on the Acromag Carrier 9670
Hi Darrell,
Darrell Nineham wrote:
> Auto Clearing the Interrupt considerably reduces the ISR Loading and
> eases the IP Code, so I am surprised it is not the default for 9670 /
> drivers.
The drvXy9660.c carrier driver that was added to drvIpac version 2.9
(which I believe can control the Acromag 9670 card) does set the CSR_ACE
bit of the Control/Status register.  My guess is that you were probably
investigating Andy Foster's original carrier driver which I haven't
looked at recently - can you confirm that?
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: IP Card Problems on the Acromag Carrier 9670 Andrew Johnson
Prev: Re: IP Card Problems on the Acromag Carrier 9670 Andrew Johnson
Next: Creating Zombies with epicsThreadExitMain Michael Abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
