Subject: RE: Creating Zombies with epicsThreadExitMain
To: Michael Abbott <[email protected]>, [email protected]
Date: Mon, 12 May 2008 06:57:24 -0400
It is not a zombe.  If a child process dies and the parent never calls wait() you get a zombe.  If the parent dies then the child's parent becomes init, which calls wait all the time. So anything with parent init is still running, probably waiting for some I/O.
Try building it with debug on (-g) and then use gdb to attach to a running "zombe" and see what it is doing.
-----Original Message-----
From: [email protected] on behalf of Michael Abbott
Sent: Mon 5/12/2008 6:08 AM
To: [email protected]
Subject: Creating Zombies with epicsThreadExitMain
I'm finding some very strange behaviour with epicsThreadExitMain on Red
Hat Enterprise Linux 4.  The default soft IOC implementation (softIoc.cpp)
exits by calling epicsThreadExitMain(), but this has a very unfortunate
effect on my system (RHEL 4) -- a Zombie process is created (apparently
owned by init, which is the first puzzle) which continues to hold its
executable file open.  I've also confirmed this on RHEL 5.
I guess there are two separate issues here:
1. Exiting with epicsThreadExitMain() appears to be a very bad thing, at
least on RHEL;
2. RHEL appears to have an unpleasant bug involving process cleanup -- how
else do I have persistent zombies owned by init?  Or else I'm missing
something...
To reproduce this, create an EPICS IOC with the following code:
	int main()
	    iocsh("/dev/null");
	    epicsThreadExitMain();
The iocsh() call is necessary to reproduce the problem.
RE: Creating Zombies with epicsThreadExitMain Michael Abbott
Prev: Creating Zombies with epicsThreadExitMain Michael Abbott
Next: RE: Creating Zombies with epicsThreadExitMain Michael Abbott
