1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem with SEQ
To: "EPICS Techtalk" <[email protected]>
Date: Mon, 19 May 2008 20:48:37 -0700
I am using seq-R2-0-11 with epics R3-14-9.  I have written a simple sequencer code in which I tried to get a value from a stringin record.  For testing I have these two definitions:
char name1[SPATH]; assign name1 to "{P}{M}WF_NAME"; monitor name1;
char name2[SPATH]; assign name2 to "{P}{M}S_NAME"; monitor name2;
Where name1 is assigned to a waveform record and name2 is assigned to a stringin record.  Both these records are given some character string values.  I can obtain the value from the waveform record but I get nothing from the stringin record.  In each case I use pvGet function.  This test was precipitated when my sequencer code failed to get the string from the DESC field of a longin record.
Is it not possible to get an ASCII coded string either from a stringin record or the DESC field from any record into a sequencer program?  It seems to me that it should be possible since it works with caget!  Am I overlooking something simple and basic? How can this be done?  Can anyone help, please?
Thanks in advance,
Zen
RE: Problem with SEQ Mark Rivers
Prev: EPICS Collaboration Meeting, Legnaro, Italy Dalesio, Leo
Next: RE: Problem with SEQ Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
