1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: question about ca arrays
To: epics <[email protected]>
Date: Wed, 28 May 2008 13:24:51 -0400
Hi all,
I setup an epics x86-ioc attached to a tcp server, the ioc listens to known size packets from the server and fills an epics waveform record with the data. The packets are ~21kB and update at ~50Hz, our clients have EPICS_CA_MAX_ARRAY_BYTES set.
One of our user reported seeing intermittent corrupt values, the rate is highly unpredictable: one bad sample every few seconds to few minutes.
I setup two minimal test clients to check what was happening -
1. one polling ca_get (which is how my user implemented his client app)
2. another using ca_monitor
(1) reproduce the problem while (2) appears trouble free.
I remember reading a post on tech-talk about string/array not being buffered and thought that might explain the issue with (1), something like concurrent read/write maybe. Could this be the issue?
Also, I was wondering if (2) is guaranteed to be consistent? Do I need to put something else in place so every single waveform update will be consistent.
Matthieu
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
Prev: RE: [APS Beamline_controls] Problems building with Microsoft VisualStudio 2005 (VC8) Tim Graber
Next: Fwd: question about ca arrays Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Power Supply Info Ahed Aladwan
