1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subroutine, chaning links
To: [email protected]
Date: Fri, 30 May 2008 23:43:45 +0200
On Freitag, 30. Mai 2008, Tim Mooney wrote:
> Ben Franksen wrote:
> > On Freitag, 30. Mai 2008, Mathias Steiner wrote:
> >> All would be well if it were possible to change links -- either .FLNK
> >> or .OUT -- from within a subroutine.  I've tried a couple of things
> >> without success.  Just pasting the channel name into the "value" field
> >> of the union does not, and probably should not, work.
> >> Assigning a different value to a link by copying an input link doesn't
> >> work either:
> >> psub->flnk = psub->inpb;
> >> This isn't so clear to me, since they are both of type DBLINK.  After
> >> all, I can "just" type the value into the .FLNK field of any channel
> >> using edm, and it'll work...
> > It works because this operation is going via Channel Access.
> > You can do the same from your subroutine: use the CA client library to
> I think I would not do this from within a sub record's subroutine, even
> though it's possible.  [...]
It's also not necessary at all. Just use plain runtime database access, see
the same named chapter in the Developer's Guide. Specifically, dbPutField()
calls dbPutFieldLink() which re-targets the link field being written to,
both are defined in src/db/dbAccess.c.
So: just do a dbNameToAddr() in the init routine, save the dbAddr pointer(s)
somewhere (DTYP comes to mind, it is reserved for device support which
subRecord doesn't have) and do a dbPutField() in the subroutine proper.
This is even simpler than the CA stuff and works synchronously.
Cheers
Ben
subroutine, chaning links Mathias Steiner
Re: subroutine, chaning links Ben Franksen
Re: subroutine, chaning links Tim Mooney
Prev: procServ soft IOC server - V2.2.0 released Ralph Lange
Next: Re: combining problem with etherip and motor Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: subroutine, chaning links Tim Mooney
Next: procServ soft IOC server - V2.2.0 released Ralph Lange
