1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Another question about mbboDirect record
To: [email protected]
Date: Thu, 12 Jun 2008 09:28:16 -0800
There was a short discussion of the mbboDirect record in march 2007 but I have found another thing about it that is annoying. It is that monitors are not posted on the bits, making the bits of the record behave differently from a collection of bo records from the point of view of edm. If you set a bo record the change will be reflected on any screen displaying controls for it but if you set one of the bits of an mbbo record that will not be the case.
The previous discussion mentioned the role of the bits in the possible closed loop operation of the mbboDirect record. I would propose that in closed loop operation the bit monitors not be posted since they would be inconsistent and not meaningful. However, in supervisory mode, for which I would argue the record must have been designed, it would be useful to have the bits post monitors. This would enable single mbboDirect records to be used rather than groups of bo records in many cases.
Carl
Carl Lionberger 510 486 7503
Software Developer, Engineering Division
Lawrence Berkeley National Laboratory
Prev: RE: Severity of I/O interrupt records Allison, Stephanie
Next: Re: camonitor prints CA errors to stdout rather than stderr Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Longout Record ? Andrew Johnson
Next: ImageJ and EPICS? Antonino Miceli
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
