1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Visual C++ link errors
To: [email protected]
Date: Mon, 23 Jun 2008 17:14:56 -0500
On Monday 23 June 2008 16:33:49 Ron Sluiter wrote:
> Anybody got a clue as to why this doesn't link.
> Specs: Visual Studio 6.0 and 7.0, base-3.14.8.2, motorR6-2-2
>    Creating library motor.lib and object motor.exp
> motorUtilAux.obj : error LNK2019: unresolved external symbol _pdbbase
> referenced in function "char * * __cdecl getMotorList(void)"
> (?getMotorList@@YAPAPADXZ)
> Apparently, pdbbase is not in dbIoc; "nm -A dbIoc.lib | grep pdbbase"
> yields no results.
pdbbase is defined in <base>/src/db, in dbAccess.c
Do you build the motor record using the C++ compiler?  No other record type
uses C++ for record implementation, so if you do you're the guinea-pig here.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
RE: Visual C++ link errors Mark Rivers
Visual C++ link errors Ron Sluiter
Prev: RE: Visual C++ link errors Mark Rivers
Next: RE: Visual C++ link errors Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
