Subject: Re: latest motor record on RTEMS?
To: [email protected]
Date: Tue, 24 Jun 2008 14:00:29 -0400
I get the following. I've tried an mvme2307 and mvme5500 with the same results.
dbior drvOms58
Driver: drvOms58
   Oms Vme58 motor card #0 not found.
Ron Sluiter wrote:
I can't address the RTEMS question, but I doubt that the error is related to the OS.
This error message occurs when the motor driver fails to establish communication
with the motor controller at boot-up (iocInit). I suggest querying the EPICS shell with;
dbior "<driver_name>"
where <driver_name> is; e.g., drvOms58, drvMM4000. You may get message like the following,
> dbior "drvOms58"
Driver: drvOms58
   No VME58 controllers configured.
value = 0 = 0x0
Hope this helps,
Ron
John M. Skinner wrote:
We're running several NSLS beamlines with 5.3 motor records under RTEMS. I got the motor code from Bill Nolan, who might have gotten it from Kate Feng. We'd like to upgrade our motor records, but I've tried 6.1 and 6.3 and I get "motor_init_record_com(): card does not exist!" errors. Is anyone using motor records beyond 5.3 under RTEMS?
RE: latest motor record on RTEMS? Mark Rivers
latest motor record on RTEMS? John M. Skinner
Re: latest motor record on RTEMS? Ron Sluiter
Prev: Re: latest motor record on RTEMS? Ron Sluiter
Next: RE: latest motor record on RTEMS? Mark Rivers
