Subject: RE: Pulse Train Record
To: "David Dudley" <[email protected]>, <[email protected]>
Date: Thu, 26 Jun 2008 09:11:21 -0400
If you have the OS tick rate at 1 K Hz,
You could set the BO's HIGH field to something .001 - 1 millisecond
set the SCAN rate to .01 Hz
It is unclear what the jitter would be on the scan task - it should be under 100 usecs if you are on vxWorks or RTEMS.
Does jitter matter or just the pulse rate?
How wide of a pulse is required?
It would be interesting to hear your results.
Bob
-----Original Message-----
Sent: Wed 6/25/2008 9:54 PM
To: [email protected]
Subject: Pulse Train Record
Is it possible to use a bo for a pulse train output?  I have an
application where I need to pulse a chemical metering pump which
requires a pulse train to control it at between 0-100 pulses per second,
and was wondering if I could use a simple digital output bit to do it,
or if I need some device support as well.
David Dudley
City of Corpus Christi
Re: Pulse Train Record Kurt Goetze
Pulse Train Record David Dudley
Prev: Pulse Train Record David Dudley
Next: Re: Question with sscan Record! Tim Mooney
Next: Re: Pulse Train Record Kurt Goetze
