1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyn / stream for http:??
To: "Burkhard Kolb" <[email protected]>, <[email protected]>
Date: Fri, 27 Jun 2008 09:46:41 -0700
Burkhard,
We use streamdevice and asyn to monitor and control Wiener VME crates via a web interface.  We build streamdevice with support for regular expressions (PCRE) -- see http://epics.web.psi.ch/software/streamdevice/doc/setup.html#pre.  I will send you the database and streamdevice protocol files.
Stephen
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Burkhard Kolb
> Sent: Friday, 27 June 2008 7:56 AM
> To: '[email protected]'
> Subject: asyn / stream for http:??
> Hi,
> I have a set of network controlled power switches from Gude
> (www.gude.info).
> They support status readback and on/off and power cycle functions
> through a web interface. Unfortunately that is the only interface.
> The vendor also supplies a perl script which can parse the
> response from
> the web server. This looks almost like a protocol in streamDevice...
> Any advice on how to get this into EPICS records?
> Cheers,
> Burkhard
> Dr. Burkhard Kolb
> KP1 / GSI
> E-Mail: [email protected]
> Tel: +49-(6159)-71-2667 / Fax: +49-(6159)-71-2185
> Gesellschaft für Schwerionenforschung mbH
> Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
> Gesellschaft mit beschränkter Haftung
> Sitz der Gesellschaft: Darmstadt
> Handelsregister: Amtsgericht Darmstadt, HRB 1528
> Geschäftsführer: Professor Dr. Horst Stöcker
> Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
> Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
asyn / stream for http:?? Burkhard Kolb
Prev: Re: asyn / stream for http:?? J. Lewis Muir
Next: Is it possible to give parameters to the Startup script (st.cmd) haquin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
