1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: unable to create virtual circuit b/c "Too many open files"
To: "Bertrand H.J. Biritz" <[email protected]>
Cc: [email protected]
Date: Sun, 06 Jul 2008 11:57:57 -0500
> I thought it has to do with the CA part due to the nature
> of the error message. But I added in some more fclose statements and
> will see if that removes the problem.
I think it's more likely because you're repeatedly calling ca_context_create() and then ca_context_destroy().  Try moving those calls outside the while loop so that you re-use the same context and I suspect your problem will go away (CA probably only expects to be used once within a single process context).
- Andrew
Re: unable to create virtual circuit b/c "Too many open files" Bertrand H.J. Biritz
CAC: unable to create virtual circuit b/c "Too many open files" Bertrand H.J. Biritz
RE: unable to create virtual circuit b/c "Too many open files" Mark Rivers
Prev: Re: unable to create virtual circuit b/c "Too many open files" Bertrand H.J. Biritz
Next: Re: unable to create virtual circuit b/c "Too many open files" Bertrand H.J. Biritz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
