1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MAXv problem update EPICS record
To: [email protected]
Cc: [email protected]
Date: Fri, 18 Jul 2008 11:47:55 -0500
Hello Jerome,
Yes, there appears to be a bug in the motor record associated with setting
the state of the limit switch indicator (RA_HOME) in the MSTA field.
Currently, RA_HOME is not getting set in process_motor_info() if
EA_PRESENT and UEIP are true.  That's not right, RA_HOME should
be set unconditionally.
I'll contact you as soon as I get a patch on the motor record web site.
Thanks for the catching this,
Ron
jerome HOSSELET wrote:
Hi all,
I use a OMS MAXV4000/ MOTOR R 6.3 / EPICS base 3.14.9 / ASYN 4.9 / vxWorks 6.2 / CPU Motorola MVME5500-0161 - MPC 7457
My problem is :
On EDM , a status HOME is always on 0 . ( I click on STATUS but nothing change)
I check with a personnal SMV function
SMV("AX RA") REQUEST AXIS STATUS
I have this response
recv_mess(): card#0 - MNNH
MAXV>MNNH<
A driver see a HOME but on EDM nothing changed
i try to caget "IOC:m1.ATHM" but it s always on 0
(I think that EPICS record was not updated)
how resolv this BUGs !!!
thanks per advance
JEROME HOSSELET
Re: MAXv problem update EPICS record Ron Sluiter
MAXv problem update EPICS record jerome HOSSELET
Prev: RE: array calc / inverse subarray survey? Mark Rivers
Next: RE: Building 32-bit EPICS binaries on 64-bit Linux systems Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: MAXv problem update EPICS record jerome HOSSELET
Next: Re: MAXv problem update EPICS record Ron Sluiter
