Subject: RE: RE: Loosing half the monitor callbacks
To: "Dehong Zhang" <[email protected]>
Cc: [email protected]
Date: Sat, 9 Aug 2008 16:10:21 -0500
When you say "raise a monitoring with the last 144 data points" what do you mean?
Are you averaging these points, or are you posting an array, or something else?
Sent: Fri 8/8/2008 5:05 PM
To: Mark Rivers
Subject: Re: RE: Loosing half the monitor callbacks
Hi Mark,
Thank you!  My ioc is indeed changing very fast -- triggered by some hardware at 720 Hz, then
every the 144th time I call the db_post_event method to raise a monitoring with the last 144 data
points.  Somehow i just miss every the other monitoring.  I tried to slow down the clock by 8 times,
it (camonitor) is still doing the same thing.
Best regards,
Dehong
----- Original Message -----
Date: Friday, August 8, 2008 4:32 pm
Subject: RE: Loosing half the monitor callbacks
To: Dehong Zhang <[email protected]>, [email protected]
> What happens when you run the "camonitor" utility from EPICS base at
> the command line on that PV?  Perhaps the PV is really not changing
> like you think it should be.
> Mark
> ________________________________
> From: [email protected] on behalf of Dehong Zhang
> Sent: Fri 8/8/2008 4:18 PM
> To: [email protected]
> Subject: Loosing half the monitor callbacks
> Hi,
> I would like to monitor a PV at 5 Hz.  Somehow I do get 5 callbacks
> every seconds
> but only get the changes every the other time, like getting changes
> 1st, 3rd, 5th ...
> two times, but never get changes 2nd, 4th, ...
> Could you please enlighten me?
> Thanks and best regards,
> Dehong
Re: RE: RE: Loosing half the monitor callbacks Dehong Zhang
RE: Loosing half the monitor callbacks Mark Rivers
Prev: Re: Loosing half the monitor callbacks Tim Mooney
Next: Re: RE: RE: Loosing half the monitor callbacks Dehong Zhang
Prev: RE: Loosing half the monitor callbacks Mark Rivers
