Subject: RE: Scan Time Definitions
To: "Matthieu Bec" <[email protected]>, "Allison, Stephanie" <[email protected]>
Cc: David Dudley <[email protected]>, [email protected]
Date: Mon, 11 Aug 2008 15:54:00 -1000
Hi Matthieu and Stephanie,
I replied separately to David, but perhaps should have cc'ed tech-talk
as well. I proposed that he could easily use event records combined with
a simple cron job to achieve what he wants. You could easily group
records with a desired scan time into a corresponding event and use a
cron job to trigger the event  via caput (or something similar).
Erik
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Matthieu Bec
> Sent: Monday, August 11, 2008 3:38 PM
> To: Allison, Stephanie
> Cc: David Dudley; [email protected]
> Subject: Re: Scan Time Definitions
> As much as I would consider adding scan "60 second", and that
> seems human readable enough, I would ponder on SCAN="4
> hours": when you get the sample would depend on iocInit time,
> not necessarily the intented purpose?
> It sounds like a problem SNL would better address, schedule
> something to happen at midnight, 4 am etc.
> Allison, Stephanie wrote:
> > Hi,
> >> The SCAN field is an enum-type. You can alter epics-base
> and extend
> >> the range of options, but it will remain enum. Are you refering to
> >> another mechanism? 'seq' records allow specifying arbitrary delay
> >> DLY<n> when to process OUT<n> links, but that's also in seconds.
> > Even though SCAN is enum, the scan task finds the # of
> seconds (which it uses to delay between cycles) from the menu
> ASCII name using strtod (see 17.3.1 of the App Dev Guide).
> This is unusual.  It would be nicer if menuScan.dbd had 3
> fields for every option - the enum value (index number), the
> user-friendly name, and the "raw" name which is used by the
> scan task.  But this is a change to epics base and probably
> not worth the effort.
> > Stephanie Allison
> Matthieu Bec              Gemini Observatory
> Tel: +56 51 205785        c/o AURA, Casilla 603
> Fax: +56 51 205650        La Serena, Chile
Re: Scan Time Definitions Matthieu Bec
Scan Time Definitions David Dudley
RE: Scan Time Definitions Allison, Stephanie
Prev: Re: Scan Time Definitions Matthieu Bec
Next: Re: Scan Time Definitions Matthieu Bec
