1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: dxp and saturn vortex on usb2
To: "Terry Cornall" <[email protected]>, <[email protected]>
Date: Tue, 19 Aug 2008 08:55:41 -0500
Hi Terry,
Can you tell if there is some resource being consumed?  Memory, files open, etc?  Can you send me a copy of the initial error messages?  Unfortunately I don’t have a USB 2.0 Saturn I can test with.
I did verify recently that on Linux it is not possible to restart the IOC without power-cycling the USB 2.0 Saturn.  This does not happen on Windows, and it does not happen on Linux with the USB 1.0 or parallel port versions of the Saturn.
From: [email protected] [mailto:[email protected]] On Behalf Of Terry Cornall
Sent: Monday, August 18, 2008 11:57 PM
To: [email protected] ([email protected])
Subject: dxp and saturn vortex on usb2
Hi.
I’m running two saturn-vortex spectrometers connected via usb2 to Centos 5 linux IOCs which are running the dxp2-8-1 packages with epics 3.14.8.2. I have libusb 0.1.12-5.1
It all works initially, (after a bit of a tussle with usb permissions) but the usb on both appears to fall over after about 20 hours of continuous running and the xerxes.c errors start, apparently about not being able to contact the vortex anymore.  (failed to locate detChan 0 and so-on)
To fix it, I power-cycle the vortex and restart Epics.  Just re-plugging the usb doesn’t do it.
Has anyone else seen this sort of thing and have any suggestions about how to cure it? I’m sorry I’m short on detail, still looking.
Thanks.
Dr. Terry Cornall | Senior Controls  Engineer | Australian Synchrotron
p: (03) 8540 4280 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
dxp and saturn vortex on usb2 Terry Cornall
Prev: FW: Is there anyone using EPICS for a FDA approved device? Deborah Quock
Next: Re: Is there anyone using EPICS for a FDA approved device? Bill Nolan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: dxp and saturn vortex on usb2 Terry Cornall
Next: Recommended display manager? Carl Schumann
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
