1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem in compiling WebCA
To: Umashankar Panda <[email protected]>
Cc: [email protected]
Date: Thu, 21 Aug 2008 09:58:45 -0400
What version of gcc are you using? It seems that it can't locate the standard headers.
thanks,
tom
On Aug 21, 2008, at 4:37 AM, Umashankar Panda wrote:
Dear All,
I am facing this problem while compling WebCA 1.1.0. What can be the
probable cause?
With regards
U.Panda
VECC, India
umashankar@umashankar:~/epics/extensions/src/webca-1.1.0> make
make -C configure install
make[1]: Entering directory
`/home/umashankar/epics/extensions/src/webca-1.1.0/configure'
perl /home/umashankar/epics/base-3.14.9/configure/tools/ convertRelease.pl
-h linux-x86 checkRelease
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
make[2]: Entering directory
`/home/umashankar/epics/extensions/src/webca-1.1.0/configure/O.linux- x86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory
make[1]: Leaving directory
make -C npca install
`/home/umashankar/epics/extensions/src/webca-1.1.0/npca'
make -C src install
`/home/umashankar/epics/extensions/src/webca-1.1.0/npca/src'
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory
`/home/umashankar/epics/extensions/src/webca-1.1.0/npca/src/O.linux- x86'
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux
-D_REENTRANT -DEMBED_CA_REPEATER -I../../../gecko-sdk/include -ansi
-O3 -Wall -g -fPIC -I. -I.. -I../../../include/os/Linux
-I../../../include
-I/home/umashankar/epics/base-3.14.9/include/os/Linux
-I/home/umashankar/epics/base-3.14.9/include ../plugin.cpp
../plugin.cpp: In function 'char* stringValue(const NPString&)':
../plugin.cpp:48: error: 'strncpy' was not declared in this scope
../plugin.cpp: In member function 'virtual bool
ScriptablePluginObject::GetProperty(void*, NPVariant*)':
../plugin.cpp:354: error: 'strdup' was not declared in this scope
../plugin.cpp:354: error: 'strlen' was not declared in this scope
../plugin.cpp:359: error: 'strdup' was not declared in this scope
../plugin.cpp:359: error: 'strlen' was not declared in this scope
../plugin.cpp: In function 'void push_connection_event(CPlugin*,
eventUserArg*, connection_handler_args&)':
../plugin.cpp:393: error: 'strlen' was not declared in this scope
../plugin.cpp: In function 'void event_handler(evargs)':
../plugin.cpp:474: error: 'memcpy' was not declared in this scope
../plugin.cpp: In function 'int parseArrayObject(NPP_t*, NPObject*,
short int&, int&, void*&)':
../plugin.cpp:646: error: 'strncpy' was not declared in this scope
ScriptablePluginObject::Invoke(void*, const NPVariant*, uint32_t,
NPVariant*)':
../plugin.cpp:787: error: 'strlen' was not declared in this scope
../plugin.cpp:834: error: 'strlen' was not declared in this scope
../plugin.cpp:957: error: 'strlen' was not declared in this scope
../plugin.cpp:986: error: 'strlen' was not declared in this scope
../plugin.cpp:1185: error: 'strlen' was not declared in this scope
../plugin.cpp:1279: error: 'memcpy' was not declared in this scope
../plugin.cpp:1290: error: 'memcpy' was not declared in this scope
../plugin.cpp:1316: error: 'strdup' was not declared in this scope
../plugin.cpp:1316: error: 'strlen' was not declared in this scope
../plugin.cpp:1323: error: 'strdup' was not declared in this scope
../plugin.cpp:1323: error: 'strlen' was not declared in this scope
../plugin.cpp:1353: error: 'strlen' was not declared in this scope
../plugin.cpp:1369: error: 'strlen' was not declared in this scope
ScriptablePluginObject::InvokeDefault(const NPVariant*, uint32_t,
NPVariant*)':
../plugin.cpp:1427: error: 'strdup' was not declared in this scope
../plugin.cpp:1427: error: 'strlen' was not declared in this scope
ArrayObject::GetProperty(void*, NPVariant*)':
../plugin.cpp:1898: error: 'strdup' was not declared in this scope
../plugin.cpp:1898: error: 'strlen' was not declared in this scope
CTRLObject::GetProperty(void*, NPVariant*)':
../plugin.cpp:2037: error: 'strdup' was not declared in this scope
../plugin.cpp:2037: error: 'strlen' was not declared in this scope
../plugin.cpp:2039: error: 'strdup' was not declared in this scope
../plugin.cpp:2039: error: 'strlen' was not declared in this scope
../plugin.cpp:2093: error: 'memcpy' was not declared in this scope
make[3]: *** [plugin.o] Error 1
make[3]: Leaving directory
make[2]: *** [install.linux-x86] Error 2
make[1]: *** [src.install] Error 2
make: *** [npca.install] Error 2
Problem in compiling WebCA Umashankar Panda
Prev: Re: Motor home status Kurt Goetze
Next: EPICS in Industrial setting David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problem in compiling WebCA Umashankar Panda
Next: Re: Problem in compiling WebCA Stefan Heim
