Wow, quite a discovery! This is a real bug in EDM. Please send the
two .edl files to John Sinclair so he can fix it. You might also
post a warning on tech-talk [[email protected]] so others can
work around the problem. At least all you work is not lost...
Steve,
Examining the text of a stripped down instrument drawing, I discovered
that the visibility works as long as the message button defining the local
PV occurs before its use in the ASCII edl file. I moved all the message
buttons up to the top, and the instrument drawing started working again.
Then I tried to change the layering of some of the objects that use the
local PV. That caused edm to shuffle the message buttons down in the
ASCII file.
Kirby
- Re: Vanishing textupdate fields John Sinclair
RE: sseq link problem on Linux Shepherd, EL (Emma)
About Runnig of epics Selim Ünal
<2008>
Re: DBFLAGS in RULES.Db Andrew Johnson
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
