1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EDM's libPV.so: what is the status of Stripchart/StripClass?
To: [email protected]
Date: Mon, 15 Sep 2008 14:32:36 -0500
I am working with two versions of EDM. The first is the approximately 3 year old 1-10-1zc. The second is the fairly current 1-11-1L. Users have already developed many screens with the older version. There is one widget/object that is supported in the older EDM that is not apparently supported in the newer version. That widget is Stripchart. In the older version Stripchart is implemented by the edmStripClass from extensions/src/edm/pvFactory/strip.cc and put into the library libPV.so. This appears to be true of the newer version also. However, only in the older version does pv_register.cc define create_StripClassPtr(). As a result the new version does not appear to support Stripchart. Are all my observations correct? I am not yet sure whether or not the existing displays use Striptchart, but if they do I am wondering what to do about it. Thanks in advance for any explanations or suggestions.
Sincerely,
Carl Schumann
Prev: Re: EPICS driver for OMRON PLC CQM1H? Paul Hamadyk
Next: Re: EPICS driver for OMRON PLC CQM1H zhangdemin99
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problem building example app for win32 using Cygwin toolchain David Morris
