1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA Gateway environment variable configuration
To: [email protected]
Date: Fri, 19 Sep 2008 16:39:58 -0500
I am trying to get a CA gateway going. The gateway logs the following:
Starting EPICS CA gateway
Sep 19 16:35:28 PV Gateway Version 2.0.3.0 [Sep 11 2008 07:53:33]
EPICS 3.14.9 PID=15076
EPICS_CA_ADDR_LIST=cag-hins-1.fnal.gov
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_SERVER_PORT=Not specified
EPICS_CA_MAX_ARRAY_BYTES=Not specified
EPICS_CAS_INTF_ADDR_LIST=clx74.fnal.gov
EPICS_CAS_SERVER_PORT=Not specified
EPICS_CAS_IGNORE_ADDR_LIST=Not specified
Running as user schumann on host clx74.fnal.gov
Statistics PV prefix is clx74.fnal.gov
It reports many environment variables as "Not specified". Should I be specifying them or will reasonable defaults be used?
Carl Schumann
Re: CA Gateway environment variable configuration Dirk Zimoch
Prev: Modbus Mark Rivers
Next: Re: CA Gateway environment variable configuration Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
