1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: EPICS perl tools in 3.14.10-pre1
To: [email protected]
Date: Tue, 23 Sep 2008 14:41:23 -0500
Hi Stefan,
On Tuesday 23 September 2008 11:18:04 Stefan Heim wrote:
> The trick is to rely on the relative location of the perl module
> directory with respect to the HOST_BIN directory rather than on absolute
> paths. Lines of the form
> use lib '@TOP@/lib/perl';
> have to be replaced by
> use FindBin qw($Bin);
> use lib "$Bin/../../lib/perl";
> in the *.pl@ tools in order to have the tools work independently of the
> absolute path of EPICS_BASE. An analogous modification does the job for
> the new CA.pm.
> I'd love to see this change (patch attached) checked into CVS before the
> 3.14.10 release. Any comments?
I like it, and actually I'll go further than you because none of the scripts
in base need to have @TOP@ expanded at all.  This simplifies expandVars.pl
which no longer needs to have the special bootstrap, but I think we still
need to include it so we can provide a way for scripts outside of base to add
the path @EPICS_BASE@/lib/perl to their @INC list.
Thanks, I will add this approach before R3.14.10 comes out.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
EPICS perl tools in 3.14.10-pre1 Stefan Heim
Prev: javaIOC Marty Kraimer
Next: Re: StreamDevice 2.4 released Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: EPICS perl tools in 3.14.10-pre1 Stefan Heim
Next: EPICS interface to Agilent Oscilloscope Dach Miroslaw
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
