Try adding this to fonts.list instead:
-adobe-times-medium-r-normal--*-340-100-100-p-*-iso8859-1
On my computer here this looks pixellated, apparently because it's not
a scalable font. It shows up in the list that appears when I select
View->Font Mappings from the edm main window as
-adobe-times-medium-r-normal--47-340-100-100-p-0-iso8859-1
I'm not sure if or how a better-looking scalable version might be used
instead.
You might have better luck specifying your fonts using the "Version 3"
font-list format detailed in the EDM documentation rather than adding
on to the "Version 1" format-file included with EDM.
-Kevin
I am trying to add more fonts to EDM. Take the following font for example:
-adobe-times-medium-r-normal--34-240-100-100-p-170-iso8859-1 I added
above line to /afs/slac/g/lcls/tools/edm/config/fonts.list and
verified that EDMFILES points to the right location:
[jingchen@lcls-dev2 config]$ printenv EDMFILES
However, I don't see the font showing up when I bring up EDM. Am I
missing any?
Is there any log option for EDM that I can track?
Jingchen
Re: ASYN R4.10 Release - code depreciation Dirk Zimoch
Re: ASYN R4.10 Release - code depreciation Andrew Johnson
<2008>
2025
EDM font sizes Zhou, Jingchen
epicsThreadSleep() and epicsThreadSleepQuantum() Mark Rivers
<2008>
2025
