1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Process 'bo' on write?
To: "David Dudley" <[email protected]>, <[email protected]>
Date: Mon, 6 Oct 2008 08:25:27 -0500
That is the behavior you will get if you set the SCAN rate to Passive.  That means the record only processes when you write to the VAL field via a database link with the PP attribute or via channel access.
Sent: Mon 10/6/2008 8:12 AM
To: [email protected]
Subject: Process 'bo' on write?
Is there a way for me to set a bo (or ao) record so that it only
processes when it's value is changed?
I've got a number of those records that I only need written to the PLC
when the value is changed.
David
Re: Process 'bo' on write? Eric Norum
Process 'bo' on write? David Dudley
Prev: Process 'bo' on write? David Dudley
Next: Re: Process 'bo' on write? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
