Subject: Re: How have folks been dealing with the Channel Archiver's 2GB index file limit?
To: Tom Cumming <[email protected]>
Cc: [email protected]
Date: Wed, 15 Oct 2008 08:45:21 +0200
Tom Cumming wrote:
On Wed, 2008-10-15 at 05:23 +0200, Thomas Birke wrote:
If our index-files at BESSY approach the 2GB limit, I usually re-create the index completely from scratch which typically produces a much smaller index-file.
How do you you, "re-create the index completely from scratch"? The only tool I know of is the, "RecoverIndex" tool that does it's thing by making educated guesses by groking the data.
The current version of the ChannelArchiver also installs a tool named "ArchiveIndexTool".
It has a "-reindex" option that will create a new index from an existing one. Maybe that'll help a bit...
I forgot to mention, that we are creating weekly archives of several different sets of PVs.
The index-files of these archives definitely never reach the 2GB limit (not even 100MB), and every monday at 2am we start a new one.
These separate archives/index-files are then combined into a "master_index" using the ArchiveIndexTool as well.
To do this, we create an xml-file (e.g. indexconfig.xml) containing a list of index-files to combine into the so-called master_index.
This master_index is updated regularly and in our case after ~1-2 years usually reaches the 2GB limit. All this is done automatically by scripts run by cron.
I just recreated our master_index (although it was not yet necessary) and it shrunk from ~1.5GB to ~1GB. It contains about 2.5 years of data from ~32000 PVs summing up to ~520GB of data.
There are sample scripts bundled with the ChannelArchiver (directory ExampleSetup) that do the job or may serve as a good starting point.
Thomas
RE: How have folks been dealing with the Channel Archiver's 2GB indexfile limit? Kasemir, Kay
How have folks been dealing with the Channel Archiver's 2GB index file limit? Tom Cumming
Re: How have folks been dealing with the Channel Archiver's 2GB index file limit? Thomas Birke
Re: How have folks been dealing with the Channel Archiver's 2GB index file limit? Tom Cumming
Prev: RE: epics dbpf problem Williams Jr., Ernest L.
Next: Re: epics dbpf problem Benjamin Franksen
Prev: Re: How have folks been dealing with the Channel Archiver's 2GB index file limit? Tom Cumming
Next: RE: How have folks been dealing with the Channel Archiver's 2GB indexfile limit? Kasemir, Kay
