1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ioc reading data from files
To: Pierrick Hanlet <[email protected]>
Cc: [email protected]
Date: Wed, 22 Oct 2008 09:43:42 +0200
Pierrick Hanlet wrote on 21.10.2008 22:00:
> [...] Until the hardware is all in place, I can use my simple setup to develop my
> edm panels, etc.  Does anyone have advice, or preferably working examples,
> of code that reads files from into ioc and the ioc writes the data to the database?
Hi Pierrick,
You just want to have your records change in a given sequence to test
your graphical user interfaces?
Then don't do it on the IOC, use a shell script instead that reads the
data from the file and write it with "caput".
E.g. if you have the file format: <channel> <value> <delay> in your
file, you could use the shell script:
    #!/bin/sh
    while true
    do
        read channel val delay
        if [ $? -ne 0 ]; then break ;fi
        caput $channel $val
        if [ $delay -gt 0 ] ;then sleep $delay;fi
    done
If you name the script "fileput" and your data file "data" you call it
"fileput <data".
Of course you need to have the location of the binary of 'caput' in your
PATH, it's part of EPICS base.
Regards
Andreas
Dr. Andreas Luedeke, SLS Operations Manager, Tel:+41-56-3104002
[email protected], http://people.web.psi.ch/luedeke
Re: ioc reading data from files Jiro Fujita
ioc reading data from files Pierrick Hanlet
Prev: RE: EPICS Threading Issues Richard Pastrick
Next: Re: ioc reading data from files Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ioc reading data from files Pierrick Hanlet
Next: Re: ioc reading data from files Jiro Fujita
