1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA and data acquisition array with variable length in waveform record)
To: <[email protected]>
Date: Wed, 29 Oct 2008 17:54:43 -0700
Title: CA and data acquisition array with variable length in waveform record)
I would like to use EPICS for one system but there is one problem where I can't come to correct solution.
Data acquisition system gets data array. Array length always changes. For example, first measurement has 2000 length array. Next measurement has 50000 length array. Then 2002, 1500, 51000, and so on.
I can create waveform record with 100000 length that will satisfy max points in array. When client subscribes it must set counts of data array. And I, definitely, don't want to transfer 100000 data array each time.
Have anyone solved this?
Thanks, Andrei.
RE: CA and data acquisition array with variable length in waveform record) Mark Rivers
Prev: FW: Tornado-2.0.x cross compiler Thompson, David H.
Next: RE: CA and data acquisition array with variable length in waveform record) Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
