1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: GPIB - asyn - streamdevice
To: "Eric Norum" <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Fri, 31 Oct 2008 11:45:56 -0700
Thanks Eric,
I think I can combine these two IOC's into one.  Once that is done, do I need to do anything special to coordinate orderly access to the two instruments or does asyn handle it for me?
Thanks again,
Zen
-----Original Message-----
Sent: Friday, October 31, 2008 10:03 AM
To: Szalata, Zenon M.
Cc: EPICS Techtalk
Subject: Re: GPIB - asyn - streamdevice
Would it be possible to run both instruments from the same soft IOC?
I don't think that it would be easy to try and mutex the requests from separate clients of the GPIB/LAN adapter.
On Oct 31, 2008, at 11:05 AM, Szalata, Zenon M. wrote:
> I have two GPIB instruments attached to ICS 8065 Ethernet - GPIB
> Controller (according to the manual this device is a replacement for
> the Agilent E2050 and E5810).  I have written two soft IOC's to
> control and monitor two instruments (one is Agilent 33220A Waveform
> Generator, the other is Boonton 4500B RF Peak Power Analyzer).  Both
> IOC programs use epics R3-14-9, asyn R4-9, and streamdevice R2-3.
> The 33220A IOC has a records with SCAN="1 second", which reads the
> status byte.  The 4500B IOC has a waveform record with SCAN="5
> second", which is used to read waveform data, a stream of ASCII coded
> floating point values.  The waveform consists of 500 data points.
> This stream of data is converted to floating point data in a genSub
> record.
> The 4500B IOC program performs flawlessly when it is the only one
> running.  When the 33220A IOC program is also running, the waveform
> data read by the 4500B IOC gets corrupted from time to time.  I
> interpret what is happening as follows: while the waveform data is
> being read, the other IOC program requests a status byte and somehow
> these two concurrent operations interfere with each other.  How can I
> solve this?  Is it possible to make reading the waveform an atomic
> operation (i.e. uninterruptable)?
> I am using the following streamdevice protocol for reading the
> waveform:
> rTDCh12{ InTerminator="";  out "TRAC:SOUR CH\$1;:TRAC\$1:INDEX
> 1;:TRAC\$1:AVER:DATA?"; in "%10000c";}
> Any suggestions will be greatly appreciated.
> Zen
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: GPIB - asyn - streamdevice Eric Norum
GPIB - asyn - streamdevice Szalata, Zenon M.
Prev: Re: how to load several same devices in stream Eric Norum
Next: Re: GPIB - asyn - streamdevice Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: GPIB - asyn - streamdevice Eric Norum
