Subject: Re: MVME6100 or 7100
To: Kate Feng <[email protected]>
Cc: [email protected]
Date: Sun, 02 Nov 2008 21:08:48 -1000
Hi Kate -
We're in the conceptual designs of rebuilding our secondary mirror control system. The original system was built with DOS over 10 years ago! It's a competent system, but certainly doesn't match our standard controllers at Gemini.
Part of this design process will be comparing a vxWorks/mvme6100 solution to an RTEMS/mvme6100 solution.
-Matt
Kate Feng wrote:
Hi Matt,
What is your application for the mvme6100 ?
At NSLS, I developed the "disco" BSP for RTEMS 4.8, which was
derived from the RTEMS-mvme5500 BSP to support the "discovery"
based boards such as the mvme5500 and mvme6100.  The BSP
works fine except the mvme6100 is not powerful enough to handle
the fast data rate of one of my applications.
I got impression from other users that the performance on the
vxWorks/mvme6100 is similar to that on RTEMS/mvme6100.  Thus,
I needed to choose a modern and cost-effective solution instead.
Hope this helps. Kate
Matt Rippa wrote:
Matt Rippa wrote:
Hi All -
Are any sites using the MVME6100 on VxWorks 5.5.2/Tornado 2.2.1? If so, would you recommend these?
Has anyone considered the new MVME7100 board? I'm not sure on the state of the BSP.
-Matt
RE: MVME6100 or 7100 Erik Johansson
Re: MVME6100 or 7100 Kate Feng
Prev: Re: MVME6100 or 7100 Kate Feng
Next: Re: GPIB - asyn - streamdevice Dirk Zimoch
Next: RE: MVME6100 or 7100 Erik Johansson
