1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: GPIB - asyn - streamdevice
To: "Szalata, Zenon M." <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Mon, 3 Nov 2008 20:11:19 -0600
On Nov 3, 2008, at 7:39 PM, Szalata, Zenon M. wrote:
Hi Dirk,
Thank you for replying.
First, a little explanation.
The instrument only sends the waveform data as ASCII coded string, no raw data option is available.
I chose to use genSub to reformat the data only because I needed to rescale it by adding offset and multiplying the result by a scale factor. These come from longin epics records.
I implemented your suggestion for the protocol and also added ReadTimeout=2000 to the protocol. This unfortunately did not cure the interference I see between the two GPIB instruments as described in my original note. So, now I have:
record( waveform, "$(P)wfTrCh$(N)Data"){
 field( DESC, "hist$(N) data")
 field( DTYP, "stream")
#  field( DISV, "0")
#  field( SDIS, "$(P)wCh$(N)Enable.VAL  NPP NMS")
 field( INP,  "@rfpmChan.proto rTDCh12($(N)) L$(L) $(A)")
 field( EGU,  "points")
 field( NELM, "1000")
 field( FTVL, "FLOAT")
 field( FLNK, "$(P)gsCh$(N)WForm PP")
rTDCh12{ ReadTimeout=2000; Separator=",";
out "TRAC:SOUR CH\$1;:TRAC\$1:INDEX 1;:TRAC\$1:AVER:DATA?";
in "%f";}
I suppose it is possible that I do not really know how to use the ICS 8065 controller, or that this device has some implementation flaw.
Eric Norum suggested that perhaps merging these two IOC's into one could lead to a working solution. What do you think? I have used epicsMutex in a device driver I wrote, but I do not see how to use something like a Mutex on the epics record level. Of course, a very simple solution would be to use one ICS 8065 Ethernet - GPIB controller for each IOC.
In the one IOC solution it might be possible to carefully arrange record scanning such that no two data reading records can scan simultaneously. It seems tricky.
I don't think that any trickiness is needed in this case. As Dirk mentioned, the command/response will be an atomic operation when only one IOC is communicating with the GPIB/LAN adapter.
The problem is that when you have multiple IOCs communicating with the GPIB/LAN adapter you have no guarantee that IOC B will not issue a request in between the command/response of IOC A.
I am quite sure that switching your applications around so that only one IOC is connected to the GPIB/LAN adapter will fix the problem.
Yes, the VXI-11 protocol does provide lock/unlock operations, but:
a) a given GPIB I/O operation already takes an awful lot of TCP/IP packets back and forth
and
b) the possibilities of deadlock seem all too likely, especially if one IOC decides to quit in the middle of a transaction.
If you really want to have two IOCs I think that it would be best to use two GPIB/LAN adapters as well.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
GPIB - asyn - streamdevice Szalata, Zenon M.
Re: GPIB - asyn - streamdevice Dirk Zimoch
RE: GPIB - asyn - streamdevice Szalata, Zenon M.
Prev: RE: GPIB - asyn - streamdevice Szalata, Zenon M.
Next: Re: GPIB - asyn - streamdevice Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
