I have once again a (stupid/nasty?) question concerning the usage of libcurses vs. libncurses In configure/os/CONFIG.Common.linuxCommon of base-3.14.10 we see the line: LDLIBS_READLINE = -lreadline -lcurses Knowing that I could redefine it with an additional, local, site-specific CONFIG.... file I still have the basic question why it is still "old" curses library libcurses, given the fact (AFAIK) nowadays (new=n) libncurses is used. (q.v. Wikipedia: http://en.wikipedia.org/w/index.php?title=Curses_(programming_library)&oldid=242733108 : "While development of ncurses <http://en.wikipedia.org/wiki/Ncurses> and *PDCurses* continues, UNIX <http://en.wikipedia.org/wiki/UNIX> curses development appears to have halted in the mid-1990s when X/Open Curses was defined" Couldn't this line be changed to libncurses, are there any reasons against it? (BTW: Typically libcurses is pointing in many systems by a symbolic link to libncurses) Just for completeness (I already solved it by changing the above line, or putting a link, or creating an additional CONFIG file): I am using an unmodified OpenSuse 10.2 installation and received during make of base, the following error picsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o -lpthread -lreadline -lcurses -lm -lrt -lgccmake -C ./libCom install make[2]: Entering directory `<HOME>/EPICS-3.14.10/base-3.14.10/src/libCom' make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `<HOME>/EPICS-3.14.10/base-3.14.10/src/libCom/O.linux-x86' /usr/bin/g++ -o libCom.so.3.14 -shared -fPIC -m32 bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.oellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLib.o devLibOSD.o taskwd.o e! /usr/lib/gcc/i586-suse-linux/4.1.2/../../../../i586-suse-linux/bin/ld: cannot find -lcurses collect2: ld returned 1 exit status make[3]: *** [libCom.so.3.14] Error 1 make[3]: Leaving directory `<HOME>/EPICS-3.14.10/base-3.14.10/src/libCom/O.linux-x86' make[2]: *** [install.linux-x86] Error 2 make[2]: Leaving directory `<HOME>/EPICS-3.14.10/base-3.14.10/src/libCom' make[1]: *** [libCom.install] Error 2 make[1]: Leaving directory `<HOME>/EPICS-3.14.10/base-3.14.10/src' make: *** [src.install] Error 2
-- Dr. rer. nat. Peter W. Zumbruch EE - department / Controls group / GSI E-Mail: P.Zumbruch_at_gsi.de Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986 Gesellschaft für Schwerionenforschung mbH Planckstraße 1 / D-64291 Darmstadt / www.gsi.de Gesellschaft mit beschränkter Haftung Sitz der Gesellschaft: Darmstadt Handelsregister: Amtsgericht Darmstadt, HRB 1528 Geschäftsführer: Professor Dr. Horst Stöcker Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph, Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
