1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: question about s7-plc driver by Dirk
To: "tech-talk" <[email protected]>
Date: Wed, 5 Nov 2008 17:23:57 +0800
hi, all:
  I am using s7-plc driver written by Dirk, while I met a problem. while the driver connetcs to plc, it will clear the data buffer of PLC to zero. the database is like following:
record(ao,"$(id):cmd_gap_pos_cmd")
    field(DESC,"command gap position")
    field(SCAN, "Passive")
    field(DTYP,"S7plc")
    field(OUT,"@Siemens_S7: 0/2 'T=UINT32'")
    field(LINR,"LINEAR")
    field(LOPR,0)
    field(HOPR,4294967295)
    field(EGUL,0)
    field(EGUF,429496.7295)
    field(DRVL,17.0000)
    field(DRVH,140.0000)
    field(EGU,"mm")
    field(PREC,"4")
  I remember the Passive mode will not write data to PLC when connecting, but why it can't work? Can anyone give some hints? thanks a lot for your help.
Best regards
Geyang  2008-11-05
Re: question about s7-plc driver by Dirk Dirk Zimoch
Prev: Re: IOC to use time from its own processor Andrew Johnson
Next: base-3.14.10: CONFIG.Common.linuxCommon: CONFIG-SITE.Common.linuxCommon not called Peter Zumbruch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: SNC/Sequencer 2.0.12 Andrew Johnson
Next: Re: question about s7-plc driver by Dirk Dirk Zimoch
