Hi Andrew,
Thanks much. Now I get a lot of:
... recGblGetTimeStamp failed
It seems the recGblGetTimeStamp method is trying to check
the timestamp event, which we don't have.
Any idea?
Best regards,
Dehong
----- Original Message -----
Date: Thursday, November 6, 2008 10:54 am
Subject: Re: IOC to use time from its own processor
To: Dehong Zhang <[email protected]>
Cc: [email protected]
> Hi Dehong,
> On Thursday 06 November 2008 09:53:43 Dehong Zhang wrote:
> > I made up a method like:
> > #include "epicsTime.h"
> > epicsTime getCurrent()
> > struct timespec ts;
> > clock_gettime( CLOCK_REALTIME, &ts );
> > return epicsTime ( ts );
> The getCurrent routine needs to take a pointer to an epicsTimeStamp
> object,
> and it returns ERROR = -1 or OK = 0. Try this:
> int clockGetCurrent (epicsTimeStamp *pDest) {
> struct timespec ts;
> if (clock_gettime (CLOCK_REALTIME, &ts))
> return -1;
> *pDest = epicsTime (ts);
> return 0;
> > Can i invoke iocClockRegister(&getCurrent, NULL) in the vxWorks
> > startup script (how ?), or I have to wrap it with a simple command
> so that
> > it can be invoked before iocInit?
> For R3.14.8 I think you should be able to put that statement directly
> in your
> startup script; replace the NULL with 0 though, and make sure you call
> it
> before any EPICS code runs that asks for the current time since that
> will
> cause the built-in routines to get registered instead. It's possible
> that
> you might have to drop the ampersand & character, but try it with first.
> HTH,
> - Andrew
> Talk is cheap. Show me the code. -- Linus Torvalds
- Re: IOC to use time from its own processor Andrew Johnson
- IOC to use time from its own processor Dehong Zhang
- Re: IOC to use time from its own processor Dehong Zhang
<2008>
<2008>
