1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: question about ca gateway
To: <[email protected]>, "'tech-talk'" <[email protected]>
Date: Mon, 10 Nov 2008 09:50:29 -0700
Hello Wantianin,
> bad request code=13 in DG
Request code 13 is a CA beacon message. I suspect that the UDP daemon of
this CA server (the CA server is a sub-component of your gateway) is
configured to listen on the wrong UDP port. Typically the CA UDP daemon
listens for search messages on port 5064, and the CA repeater daemon listens
for IOC beacon messages on port 5065.
The CA gateway configuration, due to its encapsulating both a CA server and
a CA client, is without doubt more difficult to set up correctly. You might
try sending a description of your situation, and how you have set your CA
environment variables to tech-talk where there are many experience persons
who can provide assistance.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of ???
> Sent: Sunday, November 09, 2008 8:22 PM
> To: tech-talk
> Subject: question about ca gateway
> hi all,
>       I have meet a strange question about ca gateway, in our situation,
ca
> gateway is running on a workstation , a softioc (use makeBaseApp.pl to
> create ) is running on a machine in the same subnet, the  ca gateway will
> display the following error message and then the corresponding pv can not
> be get from the ca gateway. it seems that the ioc send some udp package to
> the ca gateway which  cause the error occurs. when this ioc is running,
the
> error will occurs continually, if restart the ca gateway ,we can get  pv
> for a few seconds and then fails again. before start the ioc, if we set
the
> environment variable "EPICS_CAS_INTF_ADDR_LIST=127.0.0.1" or  set some
> other environment variable to let the ioc not to send message  to ca
> gateway ,the error will not occur,
> Is there some way of solve this problem?  ps: I notice that only when the
> ioc is complied use base3.14.9(if recompile the ca gateway in base 3.14.9
> the problem still occurs),and if the ioc is compiled use 3.14.8.2 the
> problem will not occur.
> error message:
> CAS: CAS Request: ? on 10.30.50.13:32920: cmd=13 cid=11 typ=11 cnt=5080
> psz=0 avail=a1e320d
> Nov 03 10:00:00 !!! Errlog message received (message is above)
> filename="../../../../src/cas/generic/st/casDGIntfOS.cc" line number=498
> protocol from client was invalid unexpected problem with UDP input from
> "10.30.50.13:32920"
> psz=0 avail=a1e320d
> Nov 03 10:00:01 !!! Errlog message received (message is above)
> "10.30.50.13:32920"
> psz=0 avail=a1e320d
> thanks a lot,
> wantianin
question about ca gateway 万天敏
Prev: Re: Problem with LabVIEW Shared Memory Interface to EPICS IOC Brand, Holger
Next: msi1_4 build - compile against base 3.14.10 crashes - `TRUE' undefinded Peter Zumbruch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: question about ca gateway 万天敏
Next: Re: question about ca gateway Dirk Zimoch
