1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: question about ca gateway
To: "Dirk Zimoch" <[email protected]>
Date: Thu, 13 Nov 2008 09:58:07 +0800
Hi, Dirk zimoch
     just as you said, I start the ca gateway like this:
#!/bin/bash
export EPICS_CA_ADDR_LIST="10.30.1.165:5064 10.30.1.166:5066 ..."(set the environment variable)
export EPICS_CA_AUTO_ADDR_LIST=NO
gateway -sip 10.30.50.1 -sport 6006 -pvlist /root/GATEWAY.pvlist -access /root/private01.access -log logfile.txt
with  -sip 10.30.50.1 and  -sport 6006  option, so the user set the EPICS_CA_ADDR_LIST="10.30.50.1:6006",and    they didn't set the EPICS_CAS_BEACON_LIST, so if they start an ioc,the ioc will send the udp package to the gateway's port which cause the question occurs.(they use base 3.14.9 to compile ioc) ,you mean if I compiled the ca gateway use base 3.14.10 the question will not occurs? I will try it immediately .
 Thank for you help,
      Best Regards.
     wantianmin
Re: question about ca gateway Dirk Zimoch
Prev: Re: WireSet missing with 3.14.10 Andrew Johnson
Next: Re: question about ca gateway Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: question about ca gateway Dirk Zimoch
