Hi Andrew,
Of course, the test with the caput tells us that the problem is not in
the example client program.
We've just realized that my IOC was running under VxWorks !
So I restarted the SAME IOC but under linux-x86 and then all is working
correctly.
Here is the difference you are looking for, the problem occur under VxWorks.
If you are still interrested to know more about my IOC, Here is more
about it:
we have a Waveform record using ASYN/MODBUS device support,
Some "GenSub", "ai" and "ao" records all using soft device support
=> the problem occur independently of the record type (under VxWorks only)
Regards.
Andrew Johnson a Ãcrit :
Hi Christophe,
On Friday 14 November 2008 10:34:16 haquin wrote:
We tried with the command line, and we can reproduce the problem, here
is the result:
[haquin@accep1 haquin]$ caput -c LB-DIA-ALB-TST2:Read_16bits_Reg.DESC
"abcdefg"
Old : LB-DIA-ALB-TST2:Read_16bits_Reg.DESC It's 14-NOV-2008 16:52:23.04
New : LB-DIA-ALB-TST2:Read_16bits_Reg.DESC a
[haquin@accep1 haquin]$ caput LB-DIA-ALB-TST2:Read_16bits_Reg.DESC
"abcdefg" Old : LB-DIA-ALB-TST2:Read_16bits_Reg.DESC a
New : LB-DIA-ALB-TST2:Read_16bits_Reg.DESC abcdefg
That is very interesting, and tells me that the problem is probably not in
that example client program.
Tell me about the IOC that this PV resides on, and the record type and device
support of the record itself. Does the problem also occur with other fields
or other record types? Is it limited to this particular IOC, or this
architecture of IOC?
I'm trying to find out what might be different about your installation and
IOC, because I am unable to replicate this behavior on a linux-x86 IOC here
using R3.14.9.
- Andrew
begin:vcard
fn:Christophe Haquin
n:Haquin;Christophe
email;internet:[email protected]
tel;work:02 31 45 46 61
x-mozilla-html:FALSE
version:2.1
end:vcard
- Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
- USE of CA lib: problem using ca_array_put_callback with strings haquin
- Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
SNL compiler bug (and a fix) Benjamin Franksen
How to creat 'target' IOC running on a Linux PC zhangdemin99
<2008>
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
