On Nov 19, 2008, at 2:55 PM, David Dudley wrote:
Where does the IOC shell come from?
The source is in <base>/src/libCom/iocsh/
I'm working with NetBSD, and when I generate an IOC, the shell I get
doesn't handle command history, or arrow commands.
There are three possible input mechanisms. The selection is made by
the build system COMMANDLINE_LIBRARY value, which may be EPICS (the
simplest in that it needs no additional external libraries, but
provides no command-line editing or history), READLINE (which uses the
GNU readline library), or TECLA (which uses the tecla library). Have
a look in <base>/configure/os/ for some examples.
Am I missing a library (like GNUreadLine)?
David
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- IOC Shell David Dudley
Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
<2008>
A db question about aiExample marco_hair
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
