1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: archiveviewer - Error in data header
To: Devin Bougie <[email protected]>, [email protected]
Date: Thu, 20 Nov 2008 17:01:57 -0500
Hi:
That error
> ../DataFile.cpp (105): Cannot reference '/arch/data/...'
which happens when you look at a wide time range is actually
caused by running out of file descriptors.
I've tried to keep data files open while processing one request
just in case I need to access that file again,
but eventually you might have too many files open
and then you get that error.
In Storage/RawDataReader.cpp around line 215 you should find
the start of the RawDataReader::getHeader() method.
Add a
   DataFile::clear_cache();
as shown below to close previously opened data files
before opening a new one.
-Kay
void RawDataReader::getHeader(const stdString &basename, FileOffset offset)
    if (!Filename::isValid(basename))
        throw GenericException(__FILE__, __LINE__, "'%s': Invalid basename",
                               channel_name.c_str());
    try
        AutoPtr<DataHeader>  new_header;
        {   // Read new header
            DataFile *datafile;
            if (basename[0] == '/') // Index gave us the data file with the
full path
                datafile = DataFile::reference("", basename, false);
            else // Look relative to the index's directory
                datafile = DataFile::reference(index_result->getDirectory(),
                                               basename, false);
            // If we keep opening data files, we'll hit the max-open-files
limit.
            // Close files which are no longer referenced:
            try
                new_header = datafile->getHeader(offset);
On 11/20/08 15:36 , "Devin Bougie" <[email protected]> wrote:
> Hi, All.  We've started to see "Error in data header" errors when
> trying to view more than 55 days of archived data for some channels.
> For example, if I try to plot from "-55d" to "now", everything works.
> If I try to plot from "-56d" to "now" I get an error.  Likewise,
> "-60d" to "-5d" works, but "-60d" to "-4d" does not.
> Is there anything I should look at or try before using ArchiveDataTool
> to copy the existing archive to a new one?  Here are examples of some
> of the errors we see in archserver.log.
> Many thanks,
> Devin
> 11/20/2008 14:50:31 ---- ArchiveServer 2.9.2 Started ----
> 11/20/2008 14:50:31 Client: Apache XML-RPC 1.2-a3-dev @
> 128.84.45.100:33129
> 11/20/2008 14:50:31 archiver.get_values
> 11/20/2008 14:50:31 how=3, count=785
> 11/20/2008 14:50:31 get_channel_data
> 11/20/2008 14:50:31 Method: Plot-Binning, 6168.15 sec bins
> 11/20/2008 14:50:31 Start:  09/25/2008 14:50:31.824000000
> 11/20/2008 14:50:31 End  :  11/20/2008 14:50:31.824000000
> 11/20/2008 14:50:31 Open index, key 1 = '/arch/all.xml'
> 11/20/2008 14:50:31 Handling 'YP1FIA02_GFL_cplr1_win'
> 11/20/2008 14:50:36 Error:
> ../RawDataReader.cpp (277): Error in data header '/arch/data/l0',
> '2008/11_19/20081119-3' @ 0x00D615F7 for channel 'YP1
> FIA02_GFL_cplr1_win'.
> l0/2008/11_19/20081119-3'
> 11/20/2008 14:50:36 ArchiveServer ran 4.17315 seconds
> 11/20/2008 14:51:54 ---- ArchiveServer 2.9.2 Started ----
> 11/20/2008 14:51:54 Client: Apache XML-RPC 1.2-a3-dev @
> 128.84.45.100:33136
> 11/20/2008 14:51:54 archiver.get_values
> 11/20/2008 14:51:54 how=3, count=785
> 11/20/2008 14:51:54 get_channel_data
> 11/20/2008 14:51:54 Method: Plot-Binning, 6278.22 sec bins
> 11/20/2008 14:51:54 Start:  09/24/2008 14:51:54.715000000
> 11/20/2008 14:51:54 End  :  11/20/2008 14:51:54.715000000
> 11/20/2008 14:51:54 Open index, key 1 = '/arch/all.xml'
> 11/20/2008 14:51:54 Handling 'YP1FIA02_GFL_cplr1_win'
> 11/20/2008 14:51:58 Error:
> '2008/11_18/20081118-5' @ 0x01410958 for channel 'YP1
> l0/2008/11_18/20081118-5'
> 11/20/2008 14:51:58 ArchiveServer ran 4.17804 seconds
> 11/20/2008 14:52:35 ---- ArchiveServer 2.9.2 Started ----
> 11/20/2008 14:52:35 Client: Apache XML-RPC 1.2-a3-dev @
> 128.84.45.100:33137
> 11/20/2008 14:52:35 archiver.get_values
> 11/20/2008 14:52:35 how=3, count=785
> 11/20/2008 14:52:35 get_channel_data
> 11/20/2008 14:52:35 Method: Plot-Binning, 6058.09 sec bins
> 11/20/2008 14:52:35 Start:  09/21/2008 14:52:35.093000000
> 11/20/2008 14:52:35 End  :  11/15/2008 14:52:35.093000000
> 11/20/2008 14:52:35 Open index, key 1 = '/arch/all.xml'
> 11/20/2008 14:52:35 Handling 'YP1FIA02_GFL_cplr1_win'
> 11/20/2008 14:52:39 Error:
> '2008/11_15/20081115-13' @ 0x01C6AADE for channel 'YP
> 1FIA02_GFL_cplr1_win'.
> l0/2008/11_15/20081115-13'
> 11/20/2008 14:52:39 ArchiveServer ran 4.14733 seconds
archiveviewer - Error in data header Devin Bougie
Prev: Working with sequencer David Dudley
Next: Re: Working with sequencer Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: archiveviewer - Error in data header Devin Bougie
Next: Working with sequencer David Dudley
