Subject: RE: solaris-x86 build error on 3.14.10
To: <[email protected]>
Date: Sat, 22 Nov 2008 15:09:39 -0600
I was actually making a mistake, the machine was a sparc, not x86.
But I get the same error when I correct that mistake and build for solaris-sparc when linking libCom.so:
make[2]: Entering directory `/corvette/usr/local/epics/base-3.14.10/src/libCom'
make -C O.solaris-sparc -f ../Makefile TOP=../../.. T_A=solaris-sparc install
make[3]: Entering directory `/corvette/usr/local/epics/base-3.14.10/src/libCom/O.solaris-sparc'
/opt/SUNWspro/bin/CC -o libCom.so.3.14 -z defs -G -h libCom.so.3.14 -z text            -mt  -z ignore -z combreloc -z lazyload             bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent!
 .o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLib.o devLibOSD.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o     -lposix4 -lpthread     -lm -lsocket -lnsl -lumem -lCrun -lc -lCstd
Undefined                       first referenced
 symbol                             in file
void*__Crun::vector_del(void*,unsigned,void(*)(void*)) /opt/SUNWspro/prod/lib/libCstd.a(locale.o)
void*__Crun::vector_new(void*,unsigned,unsigned,void(*)(void*),void(*)(void*)) /opt/SUNWspro/prod/lib/libCstd.a(locale.o)
void operator delete(void*,void*)                      /opt/SUNWspro/prod/lib/libCstd.a(zOtiZS4hQ7CvMDXtQoDv.o)
ld: fatal: Symbol referencing errors. No output written to libCom.so.3.14
make[3]: *** [libCom.so.3.14] Error 1
make[3]: Leaving directory `/corvette/usr/local/epics/base-3.14.10/src/libCom/O.solaris-sparc'
make[2]: *** [install.solaris-sparc] Error 2
make[2]: Leaving directory `/corvette/usr/local/epics/base-3.14.10/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/corvette/usr/local/epics/base-3.14.10/src'
make: *** [src.install] Error 2
Sent: Fri 11/21/2008 6:49 PM
To: '[email protected]'
Subject: solaris-x86 build error on 3.14.10
I'm trying to build 3.14.10 on solaris-x86.
I get the following error when building libCom.a
/opt/SUNWspro/bin/CC -xar -o   libCom.a         bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLib.o devLibOSD.o taskwd.o epic!
 .o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLib.o devLibOSD.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o     -lposix4 -lpthread     -lm -lsocket -lnsl -lCrun -lc -lCstd
 symbol                             in file
Can anyone tell me what the problem is?
Versions:
SunOS 5.10
CC: Sun C++ 5.8 Patch 121017-13 2008/01/02
RE: solaris-x86 build error on 3.14.10 Mark Rivers
Prev: Galil Motion Controllers Dropp, Christopher
Next: Re: Re: A db question about aiExample Silver
Prev: solaris-x86 build error on 3.14.10 Mark Rivers
Next: RE: solaris-x86 build error on 3.14.10 Mark Rivers
