1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RE: RE: A db question about aiExample
To: "tech-talk" <[email protected]>
Date: Sun, 23 Nov 2008 11:22:41 +0800
hi, Peter:
  Although other gives other solution. I want to try your ways too. but when I paste your code in db file. the result does not change as we expect (still change from 0-9, then 0-9).
I think if we don't use .LA field, the only way is using two calc record. but why it can't work?
======= At 2008-11-20, 22:39:12 you wrote: =======
>Full Example- changes to your original in bold:
>record(ai, "$(user):aiExample")
>field(DESC, "Analog input")
>field(INP, "$(user):calcExample.VAL  NPP NMS")
>field(EGUF, "10")
>field(EGU, "Counts")
>field(HOPR, "10")
>field(LOPR, "0")
>field(HIHI, "8")
>field(HIGH, "6")
>field(LOW, "4")
>field(LOLO, "2")
>field(HHSV, "MAJOR")
>field(HSV, "MINOR")
>field(LSV, "MINOR")
>field(LLSV, "MAJOR")
>record(calc, "$(user):calcExample")
>field(DESC, "Counter")
>field(SCAN,"1 second")
>field(FLNK, "$(user):aiExample")
>field(CALC, "(A<B)?(A+C):D")
>field(INPA, "$(user):calcExample.VAL  NPP NMS")
>field(INPB, "9")
>field(INPC, "$(user):incrExample PP")
>field(INPD, "0")
>field(HOPR, "10")
>field(HIHI, "8")
>field(HIGH, "6")
>field(LOW, "4")
>field(LOLO, "2")
>field(HSV, "MINOR")
>field(LSV, "MINOR")
>record (calc, "$(user):incrExample")
>field(VAL, "1")
>field(CALC, "(A<=0)?1:((A>=9)?-1:B)")
>field(INPA, "$(user):aiExample.VAL")
>field(INPB, "$(user):incrExample.VAL")
>I can't think of a way to do it with one calc record as you need some place to store
>whether you are going up or down.
>Pete
>-----Original Message-----
>From: marco_hair [mailto:[email protected]]
>Sent: 20 November 2008 14:08
>To: Owens, PH (Peter)
>Subject: Re:RE: A db question about aiExample
>hi, Peter:
> Would you give me detailed db? I am still confuse about that. Ps, is it possible to use just one calc record. for example: use INPA to get calc itself's value, INPB to get ai's value, then  judge if it's in increase procedure or decrease procedure?
>  Thanks a lot in advance.
>在2008-11-20,"Owens, PH (Peter)" <[email protected]> 写道:
>Use a third record to calculate the increment:
>Set
>$(user):calcExample.INPC = $(user):incrExample PP
>record calc, "$(user):calcExample")
>field(VAL, "1")
>From: [email protected] [mailto:[email protected]]On Behalf Of marco_hair
>Sent: 20 November 2008 10:57
>To: tech-talk
>Subject: A db question about aiExample
>Dear all:
>  in the aiExample.db coming with soft ioc template,
>field(EGUF, "10")
>field(HOPR, "10")
>field(LOPR, "0")
>field(HIHI, "8")
>field(HIGH, "6")
>field(LOW, "4")
>field(LOLO, "2")
>field(HSV, "MINOR")
>field(LSV, "MINOR")
>field(INPB, "9")
>field(INPC, "1")
>field(INPD, "0")
>field(HOPR, "10")
>field(HIHI, "8")
>field(HIGH, "6")
>field(LOW, "4")
>field(LOLO, "2")
>field(HSV, "MINOR")
>field(LSV, "MINOR")
>the ai value will change from 0-9 and then loop from 0 again.
>if I want to generate the value from 0-9, then decrease it, such as 9-0. That is, the value increase from 0-9, then decrease from 9-0 one by one, how can I written it?
>Thanks a lot for your help.
>Best wishes
>Geyang 2008/11/20
>[广告] 金秋最关注楼盘-房不胜房
>  _____
>[广告] 金秋最 关注楼盘-房不胜房 <http://popme.163.com/link/003985_1010_7027.html>
Best regards
Geyang 2008-11-23
Prev: Re: Re: A db question about aiExample Silver
Next: Re: CAEN V965 driver Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: archiveviewer - Error in data header Devin Bougie
