1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Device Driver Initialization routine
To: [email protected]
Date: Tue, 2 Dec 2008 15:46:02 -0600
On Tuesday 02 December 2008 13:45:59 David Dudley wrote:
> According to the 3.14 WIKI on the ai record, the ESLO and EOFF fields
> aren't configurable through the DCT.  I take it that that's wrong.  Should
> that be changed?
Yup, that's wrong; it changed when we added the SLOPE conversion mechanism,
which was needed because some generic device support layers can't know the
range of their raw values so can't implement special_linconv().  I just
changed the ai and ao pages, but be aware that there are *lots* of other
things still wrong in the wiki Record Reference Manual.
> I assumed I couldn't do anything with it, so I didn't try, and used ASLO
> and AOFF instead, however looks like I need to correct some things.
I believe those were originally intended to permit adjustment of individual
I/O records to correct for hardware issues, where the actual conversion
results differ from the design parameters.  You can of course use them
however you wish though.
> Also, if you are using LINEAR, do you have to have a special_linconv()
> routine in the driver in order to get values scaled correctly?
Not necessarily, as long as ESLO was properly set in init_record() or the .db
file.  If a special_linconv() routine is provided it will be called whenever
LINR, EGUL or EGUF are changed and LINR is LINEAR; its sole purpose is to
compute ESLO and set EOFF if its value is not EGUL.  If you never change EGUL
or EGUF (or you don't set LINR to LINEAR) there's never a need to recompute
ESLO, so not providing a special_linconv() routine would have no effect on
the value scaling.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
RE: Device Driver Initialization routine Dalesio, Leo
Device Driver Initialization routine David Dudley
Re: Device Driver Initialization routine Andrew Johnson
Re: Device Driver Initialization routine David Dudley
Prev: Re: Device Driver Initialization routine David Dudley
Next: RE: Device Driver Initialization routine Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
