1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ioc running on a server with a private network
To: Kevin Tsubota <[email protected]>
Date: Tue, 09 Dec 2008 10:06:02 +0100
Hello,
By default, channel access uses all broadcast addresses it finds on the host. That means an IOC is server on both network cards and a client searches on both network cards. Thus, when client and IOC run on the same machine, you get duplicate channel warnings. Setting EPICS_CA_AUTO_ADDR_LIST=NO and EPICS_CA_ADDR_LIST=’primary IP’ on hosts with two network cards is the correct way to solve this problem. Best do it automatically for every user in a script in /etc/profile.d/.
Dirk
Kevin Tsubota wrote:
Hi All,
I have an R3.14.9 Unix IOC running on a Solaris-8 host that actually has two IP addresses. The 2^nd IP is setup for a private network.
When I access a channel from this IOC, it warns me about multiple IOCs and references both IP addresses assigned to this server, the primary address and the private network address.
I have worked around it by using EPICS_CA_AUTO_ADDR_LIST=NO and EPICS_CA_ADDR_LIST=’primary IP’ but am curious why this is happening and if there is another way around this.
Thank you,
Kevin Tsubota
W.M. Keck Observatory
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
ioc running on a server with a private network Kevin Tsubota
Prev: ioc running on a server with a private network Kevin Tsubota
Next: DeltaTau UMAC ethernet access? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
