1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Support for shell variables in the EPICS build system
To: [email protected]
Cc: "Ernest L. Williams Jr." <[email protected]>
Date: Tue, 9 Dec 2008 12:11:22 -0600
Hi Remi,
On Tuesday 09 December 2008 11:30:18 Remi Machet wrote:
> I would like to add support for shell variables in convertRelease.pl
> (see example patch bellow that is against R3.14.9).
One problem with including this patch in Base is that it would affect the
production environments at other sites as well as your development
environment, so although it would make things easier for you, it could break
someone else's production build system (they might now be relying on
convertRelease.pl *not* reading environment variables, although I do admit
this would be a little unusual).
> I have been told that this issue was already raised some time ago but
> nothing was changed. Looking at the archives I found a post from Ralph
> Lange on Tue, 27 May 2003 titled "Re: convertRelease.pl" which makes a
> good case against using shell variables.
> But in my opinion Ralph makes a case about why some of us should not use
> shell variables, not why no one should be able to ... I totally agree
> that using shell variables in a production environment can be dangerous
> and is in my mind not worth it, but in a development environment it can
> be extremely powerful (for example to find out at which version of base
> an IOC can work with).
I have a question about your environment - how are you setting those variables
in the first place?  The convertRelease.pl script does support both include
and -include statements in the configure/RELEASE file, so might there be some
way to have those variables reflected in another file that just gets included
by the RELEASE file?  I believe the path to the include file can be relative
or absolute, so at one extreme you could have all your configure/RELEASE
files just include a common file somewhere that just sets variables for all
your installed support modules.
With a bit more information about what you're trying to achieve we may be able
to come up with a solution for you.
> I am sorry if I am re-opening an already closed issue, but I believe
> that supporting shell variables, while not for every project could
> greatly help some of us.
Discussion is good, as long as it is informed by history - you did your
research first, so no apology necessary.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Re: Support for shell variables in the EPICS build system Remi Machet
Prev: Support for shell variables in the EPICS build system Remi Machet
Next: Video solutions Terry Carlino
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Support for shell variables in the EPICS build system Remi Machet
